Basically this seems to happen more often now, this is what I do....
Extract the files from a DVD-9 using DVD Decrypter 3.1.4.0, transcode them using DVD2One 130. Then burn the VIDEO_TS & AUDIO_TS folders using Stomp 4.50.
During the last couple of percent of the verifying I get this message:
"One or more files did not compare to their originals. It is recommended you try to create your disk again."
Does anyone have any idea why this is happening? It's as though somehow the files have changed or something yet I haven't touched them.
Thank you.
Results 1 to 1 of 1
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Cannot Record Protected Movie error using Samsung DVD-HR734 recorder
By noreberto in forum DVD & Blu-ray RecordersReplies: 6Last Post: 7th Nov 2008, 15:51 -
error msg when try to record on drw-500
By harryb in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 23:57 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
