hi
I have an avi that is stuttering when I'm playing it in windows media player, and anything else i try to play it on, i though it might be my codecs, but it cant be that cos I've just done a fresh install off windows, and I'm getting the same problem with it. I also checked fro bad frames with v,dub, but that came out ok to. has anyone got any other ideas wot it could be?
There's warnings all over this site. Codec packs are evil. Uninstall any, get individual codecs as & when you need them and cross your fingers that pack has not messed up any of your programs.
Do a search here on "codec pack". You'll see.
Fingers crossed for you.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
