  1. I have 18 cartoons.. I've already made a menu to select each indivual cartoon.. Now I'd like to add a button to play all in sequential order without returning to the menu until they've all played.. Is this possible in DVDLab?
  2. Look in latest guides on front page.
    Life is what happens just when you've got everything planned.
  3. I tried that already.. Maybe I have different versions of DVDLab or IFOEdit, but the some commands are not the same. The guide was made for DVDLab Ver 1.3Beta2.. I'm using v1.1.
  4. What I can't find is how to add the "IF" command.. I'm supposed to add a command "If GPreg<13> == (cmp-val)<1028> then (LinkPGCN) Link PGC 2".. There's no command on the list.
    Sep 2001
    This is the easiest way in DVDLab...
    1) Add a button on the main menu.
    2) Link it to the first movie.
    3) In connection wizard, when it asks "what to do when the first movie finishes?" - Select go to next movie.
    With this way though, no matter what selection you choose it will always go to the next one.
    Tearren
  6. The guide does say:
    Double click it and enter this number:
    [71 00 00 0D 04 04 00 00] "
    Also check this guide for entering HEX numbers - look at part 4. :
    http://www.photosyndikat.de/guides/MultiAudio.htm
