Well,
first things first. I must say that the program has solved all my problems for the last 5 months............... until now.
I have a pioneer dv-606d and I need to apply the pan and scan patch. I also have a pioneer dv-333 which does not need the patch as it plays svcds no problem. Now, since the new update (last week), svcd2dvd apparently doesn't apply the patch so my dv-606d only shows the movie on 2/3 of the screen and even worse, my pioneer player (dv-333) only shows it on 2/3 of the screen as well. Not sure what gives? Any ideas?
Some info, movies created using tmpgenc template (svcd ntsc film) and burned automatically with copytodvd. I have tried this process 3 times in the last 3 days and it still gives the same result. HELP
Smash
SmashGuest
do you want to post your log file?
Well Chrissyboy,
I took your suggestion and used the program "ReStream" and tried one of to things with the original mpegs before putting them into svcd2dvd. I changed the header the first time and deleted the header to allow svcd2dvd to add the pan and scan info. Changing the header caused the program to crash right away while the second try just caused the program to look like it was running but it wasn't doing anything. I let it go for a couple of hours and it was still adding the header.
Anyways, I know you are working on the problem.
Smash -
Ok - I'll add the option of replacing Sequence Display Extensions. Currently SVCD2DVD justs adds SDEs. If SDEs are present it leaves them be. Existing SDE can be incorrect however.
SmashGuest
Well,
Since the SDE header is being fixed as we speak by Chrissyboy, my question to everyone else is this:
1)Has anyone else had this problem
2)If yes, what mpeg encoder did you use.
3)If you didn't have any problems with applying the pan and scan patch, what encoder did you use.
Just curious
Smash -
SmashGuest
I am just trying to find out about the different autoring programs you can use if you don't want to use svcd2dvd's authoring. No thread has be done with respect to what the settings are needed if you have to apply the pan and scan patch (SDE) in svcd2dvd.
So, to the people who use a different authoring program AND have to apply the pan and scan patch in svcd2dvd first, what are your your settings for svcd2dvd and what are your settings in the DVD authoring program so your final product still has the SDE in the mpeg file and the resulting DVD plays perfect on your TV.
Smash
Pot Player no pan scan ?
By nic3 in forum Software PlayingReplies: 0Last Post: 26th Apr 2011, 03:10 -
pan and scan vs keep aspect ratio
By tommcd64 in forum Video ConversionReplies: 1Last Post: 13th May 2009, 14:05 -
What is Pan and Scan?
By janlafata in forum Newbie / General discussionsReplies: 7Last Post: 15th Jan 2009, 21:27 -
Letterbox/Pan-Scan - Encoding or authoring option?
By ecc in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2007, 01:40 -
Pan & Scan a video file for iPod?
By acid_burn in forum Video ConversionReplies: 6Last Post: 5th Jun 2007, 23:58
