Results 1 to 11 of 11
    Mar 2003
    Singapore
    I want to create a very short slide movie... & burn with my video & make it into vcd & use it on my vcd player..
    should i say i want to create a transition with pic in it.. wht prog is the best to do it? it will be best that the prog is easy to use.. as i try adobe.. i totally blur with tht.
    i try nero vision.. it doesnt seem gd with it.. my pic went out of shape & the video also ...
  2. There are several programs for making slideshows. The best one i have seem thus far is MemoriesOnTv. It has several effects, and what i really liked about it was the Ken Burns effect. The only bad part is that if you want the MPEG2 plugin that costs extra. It's as simple as dragging and dropping folders for albums or dropping pics to albums. I really liked it.
    There can be only 1, and once you find it let me know what it is please
    Mar 2003
    Singapore
    hmm thx i get it a try =)
    Mar 2003
    Singapore
    can these 2 burn in vcd? & play it on vcd player on tv?>
    I try Slide Show Movie Maker it seem not very gd.. my pic went blur
  5. Member MpegEncoder's Avatar
    Dec 2002
    Wish I was on Catalina Is
    I'm not sure what you mean by this, but I use it to make an AVI file. Then I use TMPGEnc to create either an mpeg-1 file (for VCD) or mpeg-2 file (for SVCD). Then VCDEasy to author the (S)VCD. It works very well.
    Mar 2003
    Singapore
    now i got it thank.. but when i do the slide show on tv using photo.. it seen not working very well .. as i dont see any slide show on the tv (i only see a very fast flash) but on the pc it work very well...
  7. Member MpegEncoder's Avatar
    Dec 2002
    Maybe you could describe your process. What other programs are you using?
    Mar 2003
    Singapore
    I use Slide Show Movie Maker, i add in pic & choose substractional dissolve & it save as avi format so i use TMPGEnc to encode into mpg & burn it..
    the pic is ok just tht i dont have the substractional dissolve
    did i do wrongly?
  9. Sorry I haven't posted this earlier been on vacation.....
    I think the problem you are having with being blurry is that that the final product is coming out as vcd quality. To get the best possible display for your images on your tv you need at a minimum svcd quality, but you would want to try to get a program that supports DVD quality. Most of these "free" slideshow makers only support vcd quality which is like a 4th the quality of dvd. So you need to ask yourself one question , am i burning this to a cd? If you are it is either vcd or svcd, if you are burning to a dvd with a folder called VIDEO_TS then more than likely it is DVD qality, which is what you want for the best results. So that is why i suggested MemoriesOnTv, but you have to pay for both the program and the SVCD-DVD plugin. I do think however you get a bundle deal if i'm not mistaken....
