Results 1 to 24 of 24
    Jan 2003
    Nassau, Bahamas
    for some odd reason my tmpgenc client wont accept any of my downloaded mpeg clips, (mpeg 1 or 2), does anyone have any quick solutions for this problem, maybe its something in my environment variables.......holla back
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    Apr 2002
    The State of Frustration
    You change your Direct Show priority to being the highest one?
    Hello.
    Jan 2003
    Nassau, Bahamas
    now its telling me invalid video source..holla back....
    Apr 2002
    Your downloads files are named ".mpg"?
    Hello.
    Jan 2003
    Nassau, Bahamas
    yup, mpg as well as mpeg..why does that make that much a difference
    Apr 2002
    And you have tried reinstalling TMPGEnc, and the files run on your software players?
    Hello.
    Jan 2003
    Nassau, Bahamas
    i haven't uninstalled and reinstalled the program but mpg and mpegs all run on my other software
    Apr 2002
    After you have reinstalled it, let me know what happens.
    Hello.
    Jan 2003
    Nassau, Bahamas
    k, will do
  10. If you're trying to open an mpg file to encode it in TMPG you will need either the latest version of TMPG or the mpeg2plugin for older versions. It's available in the tools section.
    Jan 2003
    Nassau, Bahamas
    that sounds like another alternative, ill look and get back to yall
    Jan 2003
    Nassau, Bahamas
    aiight guys, ive uninstalled and reinstalled, also added those plugins, nothing seems to work, i dont know, any other ideas....mind you that i also have main concept, its just that i dont know how to work it as good as tmpgenc, and main concept accepts my mpegs, as tmpgenc accepts my xvids, i should just learn how to encode using both huh...holla back
    Apr 2002
    Do you know how to use AViSynth?
    Hello.
    Jan 2003
    Nassau, Bahamas
    no i dont, and from what ive seen from attempting to use it before , its pretty hard, im not saying i cant learn it, im just saying it will take a while, why?....what good will that prog do for me..holla back
    Apr 2002
    Well, it can make TMPGEnc open your MPEG files. Do you know how to frameserve with Virtual Dub mod?
    Hello.
    Jan 2003
    Nassau, Bahamas
    point me to the guide that will allow avi synth to open my files, let me look at it and attrempt it, no i do not know how to frameserve using v-dub mod..holla back
    Apr 2002
    Hello.
  18. Member
    Jan 2003
    Nassau, Bahamas
    k will look at it...but imma look at just using main concept for encoding my mpgs and mpegs aiight..holla back..if you can offe anything else to use
    Apr 2002
    It's your project, feel free to do what you want.
    Hello.
    Jan 2003
    Nassau, Bahamas
    LOL...COOL
  21. Hi SirCooks,
    Just ran across the same error: "Invalid video source" whenever trying to open MPG1 in Project wizard . The scapegoat seems to be one single Checkbox in "Option->Enviromental settings...->General" "Enable multiplex with..." I checked it some time ago for what reason ever. After **unchecking** it TMPGEnc loads the MPG-Files without complain . Give it a try an please report here if it worked for you.
    Hope thats helpful. Bye
    McConnor
  22. Member
    Jan 2003
    Nassau, Bahamas
    i allready figured it out man, but thanks for your post anyway
  23. Member scottb721's Avatar
    Oct 2002
    Australia
    Would frameserving with DVD2AVI be an option ?
  24. Member
    Jan 2003
    Nassau, Bahamas
    i have no idea, ive never frame served and i get the best quality dvds....holla back
