Results 1 to 9 of 9
  1. Hey all, I am using "MPEG Tools" to edit my MPEG-2 file I captured from VHS. I play the video, pause where I want it to start and hit the "Start" button. Then I play near the end, hit pause, and hit the "end" button. Then I hit run. However, it always adds on a few more minutes. I've tried this several times. What the heck is going on?!
    ontario ,canada
    To cut out the beginning and/or the end in Tmpg use the source range under the advanced tab.Ive tried using Mpeg tools to trim and it doesn't work very well at all.
    bmiller,ont.canada
    Apr 2002
    The State of Frustration
    I would use AviSynth as an MPEG scalpel.
    Hello.
    Mar 2003
    Uranus
    The preview widow is off a little .
    What you do is open the video in VdubMpeg, and mark
    the start and end points and note the timecodes of both.
    then in TMPG cut& merge you TYPE IN the timecodes
    instead of using the slider.
  5. Originally Posted by FOO
    I try to open in vdub, and it says MPEG Import Filter: packet synchronization error. Does anyone know what this means?
    Apr 2002
    It usually means you are trying to open an MPEG-2 file in Virtual Dub. Try Virtual Dub mod.
    Hello.
  7. Womble mpeg2-vcr is great at mpeg-2 cutting.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
    Mar 2003
    Uranus
    yeh but it's large money
    Read my REMOVE COMMERCIAL guide and find the TMPGENC ERROR guide at very bottom.
