Results 1 to 12 of 12
    Aug 2002
    England
    I have an earlier version of Procoder.
    Does anyone know how to use avs files with it?
    I can't browse to the avs file to add them.
    Cheers
    Fozzee
    Aug 2002
    You can use Link2 or VFAPIconv to make an intermediate "dummy" avi file which you can open with Procoder.
    Ronny
    Aug 2002
    England
    Could you tell me how please.
    Fozzee
    Aug 2002
    With Link2 just open your source avs script and generate an avi file.
    Open this avi file with Procoder. You can also use VFAPIconv instead of Link2. Check the frameserving guide:
    https://www.videohelp.com/forum/userguides/87270.php
    Ronny
    Aug 2002
    England
    Well I tried link2 but it wouldn't convert properly.
    I tried VfapiConv but it only takes TMPGEnc project files.
    So I loaded an avs into tmpgenc and saved that as a tpr file then converted that to the pseudo avi.
    Did I do anything wrong?
    Fozzee
  6. No experience pf Procoder, but I think vfapiconv should work. However, to get it to accept Vdub and avisynth files you also need to install readavs.dll. you should then have no problems opening the pseudo-avi file created by vfapiconv in any encoder.
    Aug 2002
    England
    Where can I find readavs.dll (I have tried)
    Cheers
    Fozzee
    Aug 2002
    England
    GOOD WORK
    Aug 2002
    Doesn't the link to readavs.dll in the frameserving guide work?
    Ronny
    Aug 2002
    England
    Have you tried it??
    At my end it's a broken link.
    Fozzee
    Aug 2002
    Originally Posted by Fozzee
    Have you tried it??
    Fozzee
    No, I have not tried it because i use Link2. An alternative could be open the avs in tmpgenc and save the project and then open the project file in vfapi and save as avi just as you wrote. Did it work?
    Ronny
    Aug 2002
    England
    I did try it and it worked.
    But I have since found the readavs.dll and am using vfapiconv with good results thanks for your help.
    Fozzee
