I have an ac3 encoded divx, however I have a soundbalster live which doe not have ac3 support. ALthought I have ac3 software installed, I have to turn up the volume to maximum in order to hear dialogue, which is a whisper. So I would like to convert the ac3 to mp2, so I can encode to svcd. I also have a separate srt file which I already know how to encode with tmpgenc.
I used virtualdubmod to extract a wav, and used the wav in tmpgenc, but the encoded svcd file was completely silent. The subtitles burned fine and the video was fine, but no audio.
I would like to be able to get nornal sound . How?
Thnx
Thx.!!!!!!..besweet was the key. However, I didin't have azid which is required to convert ac3 to wav using besweet. So I used virtualdubmod.exe to extract a wav from the ac3 audio stream, then input the wav into besweet to convert to mp2 using the besweet settings that dvd2svcd uses.Can hear the dialogue now.
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 13:47 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 16:53
