Hi there,
i've just bought a Roadstar DVD 2501x to play Divx.
The new firmware allows to show subtitles in SRT format when u push the "Subtitle" button on the remote.
My problem is:
Since this new firmware isnīt that good and sometimes causes the player to freeze while loading the subs, i wanted to had permanent subs to my DivX.
Is there a way to quickly join subs and avi and keep the exact avi properties like bitrate, res, etc.
Is there a way to avoid VirtualDub and Tmpgenc to do this?
I tryed AVI-MUX but with no results..
Just one more thing... I've only tryed to load SRT, SUB ans SSA but it seems it only supports SRT. Is there any other type of subs i should try?
Thanks for the support..
Rui Fragoso
Originally Posted by Greenie
The quality would be better if you go back to your source video (i.e., re-ripping the DVD) rather than re-encode an already encoded DivX/Xvid file.
Seems a good ideia... I'll try it..
The problem with VirtualDub, since in some cases i don't have the original movie, is that a have to re-encode a DivX and will loose quality, i'm i correct?
Is there a way to simply save it and retain the exact properties (+ the subs) ?Rui Fragoso -
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
ac3 avi movies don't play back in 5.1 on divx dvd player
By funkyspaceman in forum AudioReplies: 10Last Post: 22nd Oct 2015, 16:01 -
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Creating avi at 1366x768 to play in dvd (divx) player
By onemoreone234 in forum Authoring (DVD)Replies: 5Last Post: 12th Feb 2008, 07:17 -
Burning AVI file to DVD-RW to play on a Divx DVD player
By Jay8284 in forum Authoring (DVD)Replies: 4Last Post: 5th Jan 2008, 14:03
