  1. I am using Ulead DVD Movie Factory 2. Now, the Divx file in question is Star Wars SE. The file itself is only about 700MB. Now, I'm not familiar with converting the video to DVD Format so I let Ulead do it for me. But it exceeds the DVD-R. What settings in Ulead can I change to make it fit? I don't mind near perfect quality due to the fact that the movie will be released on DVD. (Eventually lol) Please help.
    Oct 2003
    England
    Hi Walker101B :P
    What i do for my dvd films is i use tmpgenc (to convert to mpg, if not in mpg format) then i use tmpg dvd author, then i use nero 6.0.0.11 to burn 2 dvd and ive had no problems doing that so far. You need the file into mpg b4 you change to a dvd format. Good luck. write back saying if this works alright. Neil :P
    May 2003
    Pal Realm
    Use the bitrate calculator on this site (TOOLS) to determine your settings in Ulead.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
