I have some video that I have shot and edited in Premiere. I now have a one minute clip that is over 200 meg. How can I get it down enough to send to my friends and family on the internet without loosing quality? I know I should be able to get it down to atleast 10 meg, but I'd like to try for 5 if I can.
Results 1 to 9 of 9
Without losing any quality is next to impossible if you only want to send 5-10 MB video over the net. If the video is in DV, you can encode it to .wmv and send it over the 'Net, but .wmv is lesser quality than DV. Use Video Studio to do it, in my opinion.
Hello. -
well, I don't mind quality loss, but just not too much quality loss.
Where can I find Video Studio? -
For sending this file across the internet to friends/family consider using the DivX format. All they have to do is download the free DivX codec (which comes with a playback program) and then they can play your DivX encoded video.
DivX format (which is MPEG-4 not MPEG-2 like DVD) will give you the best combination of compression and quality.
Try using a resolution of 640x480 and make sure you deinterlace the video for the DivX file. Use MP3 audio at 192kbps for best sound or 160kbps for nearly as good but smaller size. You can also use a resolution less than 640x480 if you need a smaller size file.
Consider using GORDIAN KNOT which is the best software I've found for making DivX files. You can get it over at the doom9 website along with guides on how to use it.
Umm, is that for homemade video? I downloaded it, but it looks like it's made for working with DVD-rips. Unless I downloaded the wrong prgram, but it's the only program I saw on their site. Unless I'm doing something wrong. Is there a walkthru or something for it?
Well DV video is in an AVI format so YES you can load a DV AVI file into GORDIAN KNOT and use it ... just make sure you deinterlace the video (since it is being made for viewing on a computer screen) and well that's about it.Originally Posted by Lord Balthazar
Yes most of the guides for GORDIAN KNOT (to make a DivX) are geared towards DVD back ups but it can be used for DV AVI video.
- John "FulciLives" Coleman
P.S.
There is an option in GORDIAN KNOT to deinterlace your DV AVI video so that the final DivX is deinterlaced."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
You have to compress the video. The size of the source makes no difference. What matters is the runtime of the source and the bitrate your choose.
I would recommend using a MPEG4 codec. There are 3 popular ones: MS, divx and xvid. The easiest to use might be the one from MS, that way if people try to play it with media player, odds are it will automatically d/load the codec if they don't have it installed.
Or you could just provide a link to d/load the codec on of your choice.
Take a look to the left under convert for how to do this. The basic process is:
1) D/load and run Virtual Dub
2) Load you video clip in VDub
3) Choose the video codec and audio codec you want
4) Save avi (not actually avi, just the extension)
You can use a bitrate calculator to choose the bitrate needed for your desired file size.
compressing video filesize for storage
By azor in forum Video ConversionReplies: 18Last Post: 18th May 2011, 01:34 -
Compressing 30+ hours of video to 10 minutes?
By nerys in forum EditingReplies: 5Last Post: 8th Jul 2010, 05:49 -
converting/compressing video
By govtphish in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2007, 01:56 -
compressing a video
By Shotobits in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2007, 11:18 -
Compressing DV video
By Duncan1382 in forum Newbie / General discussionsReplies: 14Last Post: 14th Jul 2007, 16:21
