I am using ffmmpegX0.0.9 to convert a quicktime movie with a .mov extension to a VCD.
I use the quick VCD preset. All I get is a dialog box that says 1017.
I have done the same thing with 0.0.7 version and I get a .mpg file. The only problem is that the audio is distorted after conversion. I tried to upgrade hoping the audio problem would be solved.
What does 1017 mean and how do I fix it?
fixableGuest
Handbrake Preset Confusion
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2011, 00:38 -
What preset should I use in premiere for 60i?
By theguy1991 in forum EditingReplies: 20Last Post: 8th Jun 2010, 13:18 -
Quick AVI Creator 1 pass xvid preset?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 17th May 2010, 16:25 -
PS3 Preset Anyone?
By croops in forum ffmpegX general discussionReplies: 1Last Post: 27th Aug 2007, 19:12 -
Suggestion-Editable quick preset
By ilmz in forum ffmpegX general discussionReplies: 0Last Post: 22nd May 2007, 16:52
