I've been in video production for 18 years but just now getting into DVD. Just bought the Philips DVDR75 to archive a lot of our old footage and to jump start our intro into DVD's. Basic question...I can record an edited program to the 75. How best to take the VIDEO_TS folder and use our own startup menu's instead of the default Philips without having to re-encode the whole thing? Best methods, Best software, etc ??? Does this question even make sense....?
Do a search for "vob to mpg". You need to extract any video/audio streams from the vobs in that Video_TS folder, (converting them back to mps), remux the streams, re-join and then Author.
Try the Guides on the left. Very helpful. :c)
If you have or find an editing program that can accept the vobs as input, you can skip the extraction/demux step.
-fixed typoThere's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Thanks All-
We have used TMPGEnc quite a bit but wanted to cut the 8-10 hour encode times down. We were hoping that by using the Philips DVDR75 to encode in real time- we then could just use some program to to import the files and then use our own front end menu. I'll check out DVDLab and see if that works...
Blessings-
Newbie question: What format is used in those *.mp4 files? DVD wanted
By TJA in forum Video ConversionReplies: 11Last Post: 21st Jun 2010, 13:54 -
very basic question: can I burn a DVD from video_rm & video_ts files?
By glitterla in forum MacReplies: 3Last Post: 25th Feb 2010, 12:09 -
Newbie question on mov files and how to watch on Dvd player
By helper in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2008, 07:01 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 20:45 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37
