  1. Does anyone know how to remove the vocal from the mp3 or wav file? I've tried winamp vocal remover plugin, and it didn't work, thanks
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    I have tried and have never found an acceptable way to remove the vocals.
  3. Member dwisniski's Avatar
    Apr 2002
    Florence, NJ
    Goldwave has an editing option to remove the vocals from your file. I have tried it with wav files from avi's I captured with Virtualdub to make surround speaker files, it does an ok job, doesn't completely remove the vocals, you can try it though.
