Have quite a few (legal) .wmv files on my hard drive files I'd like to author and burn. Seems very few authoring packages support this directly. Ulead DVD Workshop, DVDLab, Tmpgenc Plus - none of these will load a .wmv file. Roxio VW5PE will, but top menu isn't readable for some reason and s/w so unstable I'd really prefer something better. I'm still on Win 98 so that limits my options.
I've been burned by "consumer" s/w before, so I don't want to pay for something until I try it...
Any ideas?
Thanks, David
That's because two of those are authoring programs - not editors.
Ulead Video Studio can import wmv and convert, You can try a trial version.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
You could try frameserving from Virtual Dub 1.3c (see Tools) to TMPGENc. It supports .asf so it may support your .wmv files. That is how I would do it.
Actually TNPGEnc+ will import and convert WMV directly, are you sure you are not referring to TMPGEnc DVD Author (which won't).
Jukka -
to Gees - thanks for the tip on UVS vs. Workshop. I'll try VS and see if it works for me
To: jtommyj, sorry, but I don't know what frameserving is. To the extent possible I'd like to get to drag and drop within the program, and not manually convert each file. I can probably fit 10 files on one DVD.
I'm lookin' for easy, thought I admit I'm killin' myself finding it. -
Keep Workshop - if you can afford it. Gives you many more options at the authoring stage.
But VS can take you from conversion to authoring a disc with some basic menu templates.
Enjoy.
And - you're welcome :c)
PS - don't expect too much out of those wmv files. It won't be the quality you see on DVDs.There's no place like 127.0.0.1
does ffmpegX accept wmv as input?
By mark909 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Sep 2010, 14:02 -
Authoring Software that supports h.264
By sampalmer21 in forum Authoring (Blu-ray)Replies: 1Last Post: 3rd Nov 2009, 10:17 -
looking for a wmv conversion tool that supports Stop and then Resume
By spooky2009 in forum Video ConversionReplies: 0Last Post: 2nd May 2009, 10:05 -
.WMV Input In MeGUI?
By jatonblue in forum Video ConversionReplies: 9Last Post: 24th Jul 2008, 16:45 -
Authoring/burning application that supports half-d1?
By sharper in forum Authoring (DVD)Replies: 2Last Post: 21st Sep 2007, 16:38
