This my first post so aplogies if i seem stupid probably is me !!
I have converted my avi to mpeg with Main Concept then when I put in into Ulead movie factory it starts to convert the video as well ....I thought it would then just burn it to the DVD
Aplogies again but any help would be appreciated .....thank you![]()
In 'Ulead' as you call it (which product is it BTW, Movie Factory or DVD Workshop?), there is a setting you need to tick labelled something like 'do not convert compliant mpeg'. If you already have that ticked, your mpeg is not DVD compliant and you will need to re-encode, or let Ulead do it for you.
Are you using Movie factory? If Ulead keeps telling you it needs to re-encode I.E. "This will take some time to render...." then either you are having it change something, or the original MPG isn't compliant. You need to check that the PAL/NTSC settings match the original. make sure you match the project (S)VCD/DVD to the original MPG. In the video clip selection window, highlight the MPG then click on INFO compare the settings to ensure they are "legal". Or use something else that's not such a pain in the ass. -rob
I pop in my dvd's, it starts to play, the video/audio lags
By rko2164 in forum ComputerReplies: 5Last Post: 11th Jan 2010, 21:53 -
Menu button just starts video over
By Qun Mang in forum Authoring (DVD)Replies: 7Last Post: 13th Sep 2008, 17:06 -
when i try to play a video in vlc player it starts to lag
By icedemon in forum Software PlayingReplies: 4Last Post: 17th Aug 2008, 21:33 -
My video has to be downloaded 100% before it starts
By Jean-Sam in forum Video ConversionReplies: 2Last Post: 17th Apr 2008, 13:28 -
Funny sound on coverted AVI files?
By andy200796 in forum Video ConversionReplies: 3Last Post: 19th Jul 2007, 14:30
