I just got the DAC-100 converter. I have my VCR plugged into the input and the firewire is connected to my G4 dual 450. I can capture live tv perfectly from the connected cable, but when I try to capture a VHS tape it stutters and cuts out. I have tried other tapes, I have tried cleaing the head, but still have problem. Is it just my VCR? Anyone have this same problem?
-thorsted
What condition are the tapes in? If they are not 1st generation tapes, you are most likey experiencing video sync errors. A Time Base Corrector (TBC) should fix your problem.
Steve
14Bit/108MHz Video DAC
By siluet in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Sep 2009, 08:43 -
What's a used videodata dac-100 worth?
By zoobie in forum ComputerReplies: 0Last Post: 26th Oct 2008, 02:52 -
Have DAC-100, need HD
By The Waco Kid in forum Capturing and VCRReplies: 0Last Post: 21st Mar 2008, 18:41 -
DATAvideo DAC-15 v.s. other video processer
By perniente in forum RestorationReplies: 0Last Post: 21st Dec 2007, 10:22 -
DAC-100 dip switches
By Steinninn in forum Capturing and VCRReplies: 0Last Post: 6th Dec 2007, 20:31
