I'm a newbie and im trying to burn an svcd from a dvd. I am trying to use dvd2svcd because i thought it was easiest, however i am having probs. When i get all the names filled in and the ifo selected and hit go, this stuff is displayed and then a window pops up saying file not found.
- 10/7/01 4:37:37 PM
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.0.3 build 3
Initializing
Initializing finished.
- 10/7/01 4:37:40 PM
- Free on drive C: 6204.80 mb
- Internal rip
Preparing vobfiles to be ripped:
- F:\VIDEO_TS\Vts_01_1.vob
Ripping: F:\VIDEO_TS\Vts_01_1.vob
Ripping finished. Speed: 0
- 10/7/01 4:37:55 PM
- Free on drive C: 6204.79 mb
- AUDIO Extraction and DVD2AVI project file creation
DVD2AVI Project File Creation Failed!
Analyzing DVD2AVI Project file
What is going on? Any suggestions on another program? Thanks
Did you d/load the DVD2SVCD software bundle or just the program? I think you just got the program. Go to:
http://dvd2svcd.doom9.net
and d/load the newest software bundle and install. It has all the support programs you'll need.
Also do you have a copy of CCE 2.5SP? You can find it at:
http://www.doom9.org/mpg/dvd2svcd.htm
as well as the users guide and setup. This site has the CCE demo which will place a logo/watermark in the bottom right of your encodes. Although I hear that there's a crack to remove this -
How did you rip the DVD? Try using the internal routines instead of vstrip or smartripper.
I had this when I started and all I did was play the DVD for a minute to unlock the dvd drive. If your looking for a how to check out this site and follow the links to what your looking for. http://www.thedoghouse.ws
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
