  1. Hi guys,
    I am using the Liteon 401S dvd+rw, but i can't get it to work in DMA mode, at least.... it works, but not stable at all and whenever i click an executable located on a CD or DVD it gives me message like "this is not a valid win32 application", "not enough memory..." etc...
    When i change "DMA if available" to "PIO only" it works just fine, but Grrrrrr@#$&^@#)$^ speed is gone of course.
    Has anybody run into this problem? Is there a sollution?
    Any help will be greatly appreciated.
    Aug 2003
    check out "dvd speed ripping tips" by Dhruv.
    https://www.videohelp.com/forum/viewtopic.php?t=180270
    hope this helps
  3. Thanks for the tip. However, i tried pretty much everything i could think of, but still can't get it working in DMA mode. Whenever i set the controller mode to "DMA if available" and i put in whatever CD or DVD, doesn't matter if it's burned or bought, it does not start any executables.... it just says "not a valid win32 application" or "not enough memory to start this application".
    It sucks a whole lot, as speed is a lot slower in PIO mode (which is working just fine).
    Anybody had this problem? what can i try?
  4. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Maybe it has a problem with another drive in your system, try switching the drive around on different IDE ports and Master/Slave combinations if you haven't already tried.
