  1. I am using TMPGenc DVD authoring and I have a few high definition AVI rips that I would like to convert to DVD-R. Any suggestions? TMPGenc doesn't seem to want to convert them.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    TMPGEnc DVD Author does not convert your files from avi to mpeg, that is done with TMPGEnc mpeg encoder. I know, the similar names are confusing. Encode to mpeg first, then author and burn. 8)
  3. Originally Posted by ZippyP.
    Oh I am aware of that. My regular TMPGEnc spits it back out too; that's what is confusing me.
  4. Originally Posted by lowercountry
    And what error messaage does TmpGenc (encoder not author) give when you try and iput your high definition avi.
    It amy also help us to help you if you open the avi in virtualdub and select file->file information. Then copy that info into your next post.
  5. Originally Posted by bugster
    Virtualdub says it is an XVID file; my media player plays it fine.
  6. If you have problem open DV video, DC30+,MJPEG captured video or any AVI VFW
    Then try to change the settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the AVI VFW and increase the priority to 1 and try open the video.
