Hey all, I've captured 2 spidey live action eps from my VHS tapes to MPEG format. Each file size is about 2.3GB in size. So in DVDit, I want to have two menus, one for each episode on the disk. I set up the menu and created 6 chapter points and a button to play the whole episode. I dragged each chapter point from the timeline onto the menu and then linked the movie to the "play" button. So . . . I've got the first menu for the first ep done. Problem is it says my project size is over 12GB!!!. What am I doing wrong?! I assumed that each chapter point represents a "bookmark" of sorts, but it appears that it needs to copy the movie multiple times?! That's the only reason I can think that it is so large. Anyone have any suggestions or am I just interpreting the various tutorials incorrectly?
I would guess 2 things are going on here.
The first is that your video is not dvd-compliant. Therefore DVD-it wants to re-encode your video, using whatever its current settings are. These are probably a high bitrate CBR, so this will probably increase the size greatly.
The second is that DVD-it (AFAIK) only supports PCM audio, which is uncompressed. Your current mpegs probably contain mp2 audio, which is compressed. Therfore DVD-it will uncompress the audio, also taking up much more space.
Solutions: Well, you could re-capture, ensureing your captur setup was dvd compliant, or you could re-encode using TmpGenc, or CCE, or mainconcept. That would fix the video problem. As to the audio problem, if you want to use compressed audio you will need a different authoring program.
BTW, mp2 audio is not supported by all DVD players, especially ones sold in N. America. All Players will support Ac3 or PCM though.
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Question: Long horizontal scratches on VHS tape
By bisonrav in forum RestorationReplies: 12Last Post: 6th Mar 2010, 07:09 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08
