    Mexico
    Does anybody have sucessfuly make a XCVD or SVCD for this player ?
    If so, please share the used parameters(resolution, Video & audio bit rate & rate control mode)
    I'm having audio and video sync problems with XVCDs.
    Regards.
  2. I made XVCD res. 480x576 25fps PAL at 2500bitrate. They work fine on my dav-s300. The sync problem could be caused kind of encode you are using. I use TMPEG 12a and works fine.
    Ciao
