I have been using dvdx copy express to do my movies,but it is just the movie. Is there another prog that is just as easy to use that allows me to add which files i want to burn? For example i have a dvd that is only 4.32 gig ,i want to copy the whole thign and not just the movie. Any help would be great! Thanks!
DVD Decrypter ISO read - ISO writeOriginally Posted by sLiMjOnEsYYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Well, I hesitated saying skip shrinking, not knowing what media's being used. I know people can have problems going close to the edge with certain media.
4.32's pretty close. I'd try 4- 4.2. Should be indistinguishable difference as far as quality.
But only if you've ever had problems with discs playing toward the ends. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
program
By maxone71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2011, 06:23 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 13:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
Program to use
By NP11073 in forum EditingReplies: 6Last Post: 17th Nov 2008, 08:35 -
Next Best Program?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2008, 13:02
