I use DVD Shrink to shrink my DVD's then use CopyToDVD to burn it. It says that I write the DVD at 2x. I have that HP DVD writer 300i which can burn at 4x and using Memorex DVD+R 4x. I changed the settings in CopyToDVD to write at 4x but when I start the burn...it says its burning at 2x. How do I make it burn at 4x?
Results 1 to 9 of 9
Hi Drewness
I've had the same prob as you but i use tmpg dvd author to put my films into dvd format (.vob) then i use Nero 6.0.0.11 When i'm buring my dvd's it says 2.4x write and i set it to 4x so try re installing it because that worked for me or use Nero 6.0.0.11 i would think if you reinstall copytodvd it mite work overwise try Nero 6.0.0.11 or higher and that should write your dvd's at 4x and it should write the film in about 17mins 30 secs depending on the size off the file. I'f this doesnt work just post a message saying and i'll get back to you if i can find anything.
Nelly a.k.a Neil :P -
I burned at a bunch of different speeds and it always sats burning a 2x so must be a bug...
-=[ JHMac ]=-
Experience is something you don't get until just after you need it. -
I'm happy thats sorted your problem out. If you need anything else just e-mail me at leonard_neil87@hotmail.com Neil :P
I too have the HP 300i(aka 300n) and cant get 4x speed burn. I have burned over 200 dvds, all at 2.4x speed. Using, NERO, RECORDNOW, TMPGENC, ULEAD......all at 2.4x....
HP tells me there is no firmware yet that will support 4x speed burn on this model yet, but the jokers are selling it as 4x speed burner.....
Anyone know what firmware I can use to get the 4x speed burn?
Im open to suggestions.
Burning with CopyToDVD for DLP
By ckurowsk in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2008, 01:37 -
CopytoDVD Issue
By Cybrex in forum DVD RippingReplies: 1Last Post: 30th Jun 2008, 19:14 -
Error I get after I finish copying a dvd with copytodvd
By litzg5 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2008, 15:17 -
CopytoDVD states media does not have enough space - error message
By marke67 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Sep 2007, 06:52
