My car head unit is happy to play an MP3 CD.
I have made a number of discs with a number of albums on each.
However, each disc puts the songs in name order rather than track order. Some of the tracks mix into the next track to seem like one continuous flow - but obviously being in name order, this doesnt sound great!!
I have used XPs basic compile thing and right-clicked in each folder (album) and arranged in track order rather than name, however they always revert back?!
Nero also puts them in name order GRRR, how can I do it please clever chappies!??
Results 1 to 11 of 11
This is that block of text which gets added to all the posts I create. There is a 255 character limit.
I'm not sure what you do exactly, by why not rename them numerically?
01, 02, 03..............There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Looking for a simple way to click 'burn in track order'
7 or 8 albums per CD
3 or 4 CDs... That's a lot of renaming!!
Thanks for the help though!!This is that block of text which gets added to all the posts I create. There is a 255 character limit. -
Well - good luck. Maybe an idea for next time when you make the mp3s.
Album number, then sequential track numbers
Gotta ask - what exactly is a "head unit"? :c*There's no place like 127.0.0.1
but there is no "track order" on data CDs. the order of the files is determined by whatever software is reading the disc. for example in windows you can sort the files by name, size, date modified, etc.
the only way around it is to name the files 01, 02, .. 10, 11, 12 etc. then your unit will play them in the correct order.Swim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Head Unit is basically a car radio, named that coz it is the main (head) unit of all the audio equiptment in the car.
Think I have made a bit of a break through... I can sort them by Created Date and as they are ripped from CD, track one was created before track two!!
However, still need the help - not all the tracks were from a CD.
and as for ripping with "01" at begining, I am a bit of a weener and have all my mp3s in the same format already - plus the head unit displays the file title and it looks a little ugly :PThis is that block of text which gets added to all the posts I create. There is a 255 character limit. -
oh.. the reason i say name the songs 01, 02, etc and not just 1 and 2 is because some devices read the first digit.. um.. first, and base the track order from this.
eg, track 1, track 10, track 11, track 12, track 2, track 21.. etc
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Yeah, thats wat W1nd0ws did the first time. Kinda dumb!!
Thanks anyway people.This is that block of text which gets added to all the posts I create. There is a 255 character limit. -
Does your car stereo support M3U lists?If so use RecordNow Max and I think Roxio products support M3U.
To me, the easiest (also free) is to rename each track by adding a track number in front of the title as suggested by others. Download a freeware program called "The Rename Program". I think I found it on ZD-net. With a few clicks, you can easily do this. It's a general purpose file renaming utility that I have used quite a lot for such renaming jobs. It's very easy to add a number with "leading zeros" if necessary. There are lots of other "renaming" utilities that would work as well. Just do a search on ZD-net. Hope this helps.
wwaag -
I am having the same problem with Mp3 songs in the computer's hard drive as they play as in alpha order instead of track order.
The only way to fix this to add a, b, c, d, etc just before the song title in a folder of the album.
Examples: A-Mr Bojangles.mp3, B-Happy Day.mp3, C-Coming Home.mp3 OR A-Track 01.mp3, B-Track 02.mp3, C-Track 03.mp3
This is the only way, use the alpha as the numbers won't work in the computer.
Playing Cd mp3 files in order
By ranchhand in forum AudioReplies: 3Last Post: 19th Sep 2011, 09:53 -
Any benefits in remixing a mp3 track?
By Anonymous5394 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2010, 07:03 -
Changing VOB file audio track order
By mmdmmd in forum EditingReplies: 1Last Post: 4th Oct 2009, 15:12 -
Burning MP3 onto CD - Software - Arrange files to my order
By UmmAddan in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2008, 21:48 -
Automatic MP3 track numbering
By UncleBose in forum AudioReplies: 2Last Post: 8th Aug 2007, 00:54
