Now I've tried all three.
I'm using the same source video (1.5 hours PAL - DivX) and trying to encode into the same target using the same bitrates. This is what I have found:
Creating a PAL DVD (4000 bps CBR)
* Procoder
Very slow (about 10 hours) but extremely good results. I can't see any degration at all.
* TMPGEnc
Faster than Procoder (about 5 hours) but with less good results. Not bad but I can clearly see that the quality has degraded since the AVI
* MainConcept
Extremely fast (about 1.5 hours) but really not that good quality
The file sizes is almost the same by the way.
So my quiestion is: I've heard people screaming loudly that MainConcept is creating both the fastest and the best encoding but with my results there's a MILE difference betweeen Procoder and MainConcept. Am I doing something wrong? I'm using the default settings with MC and I would really like to use MC for my encodings since it's so fast but at the moment the quality is'nt very good at all.
Has the quality improved in v1.4? (I'm using 1.3)
The only encoder I'm satesfied with at the moment is Procoder which produces the results I need, however it's not fun to be waiting 10 hours with a 2MHz computer for it to be done.
Can anyone point me to a page with a more accurate comparison if there is one?
/Totta
all 3 encoders can produce excellent results -- tips on settings for MC are listed on this forum ... default settings are not it .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_MWant my help? Ask here! (not via PM!)
TMPGEnc XPress 4 seems okay, will ProCoder do this better?
By tluxon in forum Video ConversionReplies: 2Last Post: 14th Apr 2009, 18:16 -
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 10:51 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
