I have been making vcds for a couple of years, but I am very new to making dvds. I have done everything I could read on the forums and through friends advice. I have gotten the vobs ripped to the hard drive and they play beautifully, but when I try to make a data dvd, it doesn't work. I have tried the Sony software my drive came with and EZ CD Creator 5 Platinum and the Record Now Max demo. None of these programs makes a readable dvd. I am putting all the files in a folder titled video_ts and just moving the data to dvd-r or +r. Can anyone think of something I am doing wrong? I am going crazy!!
Results 1 to 13 of 13
You should also create a folder called audio_ts and copy that to the dvd. The folder should be empty - it is often needed for compatability with some DVD players.
Most people soon abandon the software supplied with their burners. Probably for good reason.
Have you looked up how others do it in the guides? And what they use/recommend? Maybe a start to finish guide will help you get one working disc, then you can deviate from there, if you choose.
And - for a second post (above) that's a nice little tidbit of info. :c) Always include that folder as a "just in case" task. Takes 2 seconds.
And, as Foo said, the AUDIO_TS s/b all caps as well.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Do not ever use EZcd 5 or under on XP, it overwrites needed files on XP, btw, XP already uses ezcd aka Roxio
Originally Posted by Shannafey
Originally Posted by ShannafeyYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Thank you all for the advice. Tompika, I have everything in the folder, not just the vobs. as for everything else,
Yes, the computer reads it just fine.
No, I haven't tried the audio_ts folder, though I have thought about that.
As for the all caps. That's what I was told, but everytime I make it all caps, windows just makes it lower case again. How do I resolve this?
Just in case it's an issue, I am running Win98SE and a Fat32 drive. -
It has to be in caps because this is part of the DVD spec. Try this with W98: Start > Settings > Folder Options > View > Allow all uppercase names. You also should know that W98 uses the Fat32 file format that doesn't like individual files sizes of 4GB or more. But that doesn't seem to be your problem.
Nero can be downloaded for trial use too.
If you want to copy a DVDR (or a DVD5) just use DVD Decrypter ISO read-ISO write, no other tool necessary
If you have the VIDEO_TS (<4.37GB)on the HDD then make an ISO image with IMGTool Classic and burn the ISO with DVD DecrypterYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Redwuz, Thank you, I've been pulling my hair out trying to figure that out. I will try that.
Thanks, Tompika, I know how to do an image, and that works fine, but I wanted just certain materials on the disc. -
Well, I've tried all caps, I've tried an AUDIO_TS directory, nothing works. I don't know what to do. I thought I was missing something, but according to you guys, I am not. I have heard that Record Now Max is the best for this, but it doesn't work. I will try to download the Nero demo at work where I have a T1 line, not at home on my 32000bps connection. Believe it or not!!
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 00:10 -
Avi->DVD no Video_TS folder
By gaikoku in forum ffmpegX general discussionReplies: 7Last Post: 13th Sep 2008, 12:11 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 06:16 -
VLC - plays DVD from video_ts folder?
By qpskfec in forum Software PlayingReplies: 9Last Post: 21st Nov 2007, 13:38 -
Burn an already authored DVD-Video folder(VIDEO_TS)
By jain30 in forum Authoring (DVD)Replies: 2Last Post: 12th Jul 2007, 09:02
