hi erm i have an avi that requires a divx codec and i want it to run on my dvd player *which plays normal avi's* is there anything i can do! I know nuthin![]()
Results 1 to 30 of 47
Try Virtual Dub mod. Load it and save it under a different codec.
Hello. -
Hmm - first I'll cut and paste what I just told the last "help me" person :c)
Next - try DLing Gspot - it is in the TOOLS section. It will help you see what codec was used on that avi and whether or not you have it.some friendly - hopefully helpful - advice. Go back into your original post, click edit, and change the title of your post subject to reflect your question.
A lot of very helpful people here might skip over posts that just say "help" and go to others where they know what the problem is before even looking.
If it is a true divx, do you have the latest codec? 5.1? www.divx.com
Oh, and ......... WELCOME :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
i dont think you guys are understanding what i mean!!! my dvd/vcr combo plays avi's if there on a cd! i downloaded an avi that i want to watch, it needs a divx codec to work (i needed to re-install divx)!! i want to watch this avi on my dvd/vcr combo, how can i convert or edit this avi so i can watch it on my dvd/vcr combo??????
You load it into Virtual Dub, select the new codec you want, then save it on your hard drive. Then burn it onto your CD to be played on your player. Do you think you understand what we mean?
Hello. -
All you've said so far is "normal" avi and that it needs a "divx codec". Can't help you any more than what was said above.
Only you have that "avi". Only you can tell what that "avi" is and what it needs to run on your player "which plays normal avis".
You were given good info to find out, but come back with only that we don't understand.
You need to supply thorough information if you want thorough answers.There's no place like 127.0.0.1
To be more precise:Originally Posted by Tommyknocker
Under audio select "Direct Stream Copy".
Under video select "Full processing mode", in Compression select your compression codec (divx?).
Under File select "Save as avi" and wait.
Burn to disc.
"Art is making something out of nothing and selling it." - Frank Zappa -
Zippy, he wants a AVI burned to CD that does not use a DivX codec, so he can play it in his player. He calls the new AVI file he wants a "normal" AVI. I do not know what AVIs play in a player, but it appears that DivX AVIs don't
Hello. -
No such thing. Avi files can be created using any one of several audio and video codecs, although there are a few commonly used ones. Gspot will analyze the file and tell you what codecs are required.Originally Posted by shinobivsdragon87"Art is making something out of nothing and selling it." - Frank Zappa
I thought that most avi players used divx.Originally Posted by Tommyknocker
Don't know and don't care. Just trying to explain what I thought he wanted.
Hello. -
@shinobivsdragon87
Post the type and brand of your DVD-player, perhaps we can find out for you what kind of AVI's it can deal with.
tis an aiwa HV-DH1k! i classed it as normal avi cos i know nuthing :P thank you for your help, i know i may seem a bit inpatient, just i want to watch this on my plyer :P thx for ure help
ive had an idea! maybe i can look at one of the avis that work on my dvd player and c what its codec is! then can i convert it in virtual dub????? ill check back in the morn and c what u guys think!!
Sounds like a perfect solution!
Good thinking!
Why don't you try to answer some of the questions that have been asked by the other people so they can help you out, cuz I still have no clue what kind (type) of player you have. If we know a bit more about the specs we can help you out, work with us here cause we know Jack about you, Jack.
Might help if you use actual words and sentences too.
This is a forum, not a mobile. Lots of people are trying to help you. Give a little. :c)There's no place like 127.0.0.1
Using proper ENGLISH should not be a problem. After all, you are from England. Most of you BRITS are better at this than us YANKS.
Post the type and brand of your DVD-player, perhaps we can find out for you what kind of AVI's (or other formats) it can deal with.
i did actualy post it up there ^^^^^^^ its an awia Hv-Dh1k i found the booklet this morning and edited that post! sorry i can c im annoying the hell out of you lot
ohh what specs do you want pc????
Nice one, editing your post so now it shows the type. Very funny, Ill make very special WonTon soup for you
OK, never mind, searched for the AIWA Hv-Dh1 on the left side of the screen and it gave me the following results;
CDR CDRW DVD-R DVD-RW VCD MP3 VBR 196kbit/s
Don't see DivX, are you sure the AIWA can play these? -
noo i said it couldent! bah im confusing every1 now even myself! erm but it plays avis! so i thought the codec could be compiled into it or something. Im just getting all confused now >_<! Ill start from the top! i have an avi that needs a divx codec on my pc! (div3- video and 0x0055(MP3) ID'd as MPEG-2 Layer 3-audio (which worked without divx installed)! can i include the codec into the avi so it doesnt require divx or am i just making no sense at all?
it said it on the box and i have t3 on two standard discs and it works! oh and thank you guys for your help ure al gr8
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator bugster
AVI with DIVx or XVid codec?
By Sierraguy in forum Newbie / General discussionsReplies: 9Last Post: 8th Feb 2011, 11:47 -
WMV to AVI Using DIVX Codec Question
By TufrThanu in forum Video ConversionReplies: 8Last Post: 15th Nov 2008, 11:58 -
The best codec/settings & application to run a 1080p flawlessly?
By r2builder in forum MacReplies: 8Last Post: 19th Apr 2008, 18:47 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 23:53 -
Configuring settings when converting to AVI (DivX codec)
By firas_hashim in forum Video ConversionReplies: 15Last Post: 24th Jun 2007, 03:21
