log
  1. I was converting two merged mpgs and the pc crashed and i could see some of the log section but not all of it and had to reboot
    I noticed it said that it checked the mpg for something but found zeros but carried on anyway. : - S
    Where does the Log file get stored from the program, ive searched the pc but cant find it
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    it resides in C:\Documents and Settings\Chris\Local Settings\Application Data\Badgersoft\SVCD2DVD\1.5.1349.33134
    (depending on your username & build)
