Hey everyone, Just a quick question. I have some analog 8mm tapes I need to capture. What is the max bitrate needed for exact copies? I thought I read somewhere that at the very most 8000 is the best. They said if you were to go to 10000 you wouldnt see any difference.
So I guess my question is........which is the highest analog tape needs. If I can get away with 8000 versus 10000 and save some room I would like to but if there is a difference between 8000 and 10000 then I will go with 10000.
Thanks for all the help and if I have no idea what I am talking about or don't make any sense don't be afraid to say so. :P
Hatz
Loves the funeral of hearts.....
I would say 3-5K, to have overhead but not to much. I think the input is what really matters.
The input??
Do you mean the quality of the tape and what not?
HatzLoves the funeral of hearts..... -
You would also be over maximum bitrate.They said if you were to go to 10000 you wouldnt see any difference.
detailed here:Video:
Up to 9.8 Mbit/sec MPEG2
https://www.videohelp.com/dvd
page down a bit to average bitrates under Video File Comparison.
There's an expansive doc here: http://www.dvddemystified.com/dvdfaq.htmlThere's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
What's your final resolution going to be? Higher res. requires higher bitrate.
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 03:15 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Analog tapes to PC
By stellabelch in forum Capturing and VCRReplies: 8Last Post: 23rd Oct 2009, 12:57 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43
