I just noticed that I was able to burn a VCD using Nero that contained both an .avi file and a .mpg file on another track. I thought that Nero was only able to burn VCD format using mpegs? If this isn't the case, why would I convert my .avi's to mpeg using TMPGEnc? Why wouldn't I just burn them straight to disc as .avi's? Now, I'm guessing, but mpeg's are probably a better quality than .avi's right?
Cheers
Actually, I believe NERO converts the AVI to MPEG, before burning to the CD; that's why you'll notice it takes longer. They say that TMPGenc produces better quality MPEG's than NERO.
Whykeekee,
You say: "why would I convert my .avi's to mpeg using TMPGEnc? Why wouldn't I just burn them straight to disc as .avi's?"
I say: so look at your .avi file SIZE and the .mpg file SIZE(after conversion).
A simple video track music (about 5 minutes) has 1~1.5GB and the same video music will take only 60~90MGB after encoded with the same quality.
Bye.
mpg editor to work with DVD styler?
By KaiserD2 in forum EditingReplies: 13Last Post: 20th Apr 2011, 15:29 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Sony .MPG files don't work on Mac? Is that true? Can I convert them?
By zernalaw in forum MacReplies: 2Last Post: 30th Nov 2007, 13:15 -
Nero Recode for mpg and vob to avi for Archos
By drstew in forum Portable VideoReplies: 3Last Post: 30th Sep 2007, 09:55 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 11:34
