Is there a particular way to convert a dual layer DVD (it says "DVD 9" on it) to mpeg. Seems like I can only get half the DVD to extract from DVD Extractor. There are scenes/chapters on the disc that simply don't open up when extracted. It's not a double sided disc, and has about 8 gigs on it, which to me is kind of weird, but I assume it's part of the technology. Any help would be appreciated.
just use 0Sex and rip as one .vob. rename the .vob to .mpg.
There you go. -
its true that works, but you wont get the audio to work in say quicktime with this method will you?Originally Posted by ZeroSix
ive always assumed you have to pull the .m2v and .ac3 (converting .ac3 to say .mp2) and then muxing them to have a .mpeg. -
gotcha
just trying to clarify incase he/she didnt know that alredy
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 10:36
Quote![Computer details: OSX 10.2
800 mHz G4
60GB
512MB
Geforce 2 MX [crap]
Panasonic Q [SL-GC10], AVX-100 Divx Player
Apple Superdrive
PowerPC G4
Edirol UA-20, iPod, Midiman Ozone, AVX X-100 Comp](/images/buttons/computer.gif)
