Currently I have a whopping 64MB RAMSo as you might of guessed i'm going to upgrade to at least 256MB RAM. So how do find out if my motherboard supports PC 133?
Results 1 to 12 of 12
Call the company you intend to purchase the memory from. Have your computer specs handy. Their technical support personnel usually have this answer for you.
Hello. -
Is there a way to find the exact name and model of my motherboard? All I know is it's an Intel because that's the first thing that shows up when booting up my computer.
Other than opening up the case and looking for a label, not really. However, if you bought the computer from a major vendor, go to http://www.crucial.com/ and enter the information for the computer. It may be able to tell you the answer.
But here is some good news for you. If you are only wondering if your computer is either PC100 or PC133, then if you just get the PC133 you should be ok. It will downclock to 100 if need be."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
I have run PC100 in 66Mhz boards with NO bad effects! I have purchased PC100 memory that tests past PC133 specs. If you buy PC133, you should be fine, it will just be running slower than maximum. It should be the same as underclocking your machine to save on the heat load. In fact I have one machine that only has a 133Mhz buss but it takes PC2100 and up memory simply because the sockets are cheaper! Via ITX M-9000 board if you want to check my facts. If it were me, I would buy the PC133, and not worry.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
OOpsOriginally Posted by Solarjetman
didn't see that.
This one really annoys me.
Why do so many people think that a slow buss won't charge a fast RAM module?
The rise and fall of voltage on a 66 mhz board has all the time in the world to charge a cell on a 100/133 module. A 100/133 board generally can't charge a slow 66 mhz module. The voltage drops off so quickly that the cell is not "set" on or off.
Besides which, 100 is getting to be so damn expensive, if you can use 133, buy it. Looking for 66 is looking to spend beau coup bucks, as well as buying some antique RAM that you will never be able to use again. -
Anybody priced 72 pin simms lately?
No but I priced some PC133 ram and found it more expensive then the DDR. Sad cause I'd like to upgrade this imac I'm typing on...
This weeks office max circular has 128MB PC133 for $9 after rebate, 256MB PC133 for $19Originally Posted by flaystusCendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
About a year ago I was pricing FPM memory (the type used back in the days of the 486 for people who do not know). And for 32meg modules the cost was something like $50!!! Of course, that price is for new modules. You could get a much better deal off eBay I would thinkOriginally Posted by The village idiot
If you do not mind buying used memory you could get some in the following place http://www.compgeeks.com/products.asp?cat=RAM, but I really think you will find better deals in e-bay.
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Have DAC-100, need HD
By The Waco Kid in forum Capturing and VCRReplies: 0Last Post: 21st Mar 2008, 19:41 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 10:59 -
JVC 100
By MeekloBraca in forum DVD & Blu-ray RecordersReplies: 4Last Post: 1st Jun 2007, 10:00 -
Percentage (%) going over 100 %
By enzofsilva in forum ffmpegX general discussionReplies: 2Last Post: 23rd May 2007, 23:26
