Hello
Im have a big problem. Im using DVDMaestro to authorize my movies. First i use SmartRipper to demux the movie to .m2v and .ac3. And after that i fix all the menu stuffs and subtitles. But the problem is this:
If i want to check if the movie and the sound is synced i have to compille the movie first. And if it isnt then i have to go back to Maestro and move the audio some mm to the left and then compile again. Is there any faster way so i dont have to compille everytime i want to check if the audio and movie is synced?
I have heard about a codec that lets you get a RealView whille playing with your movie in Maestro. What is the name of that codec and were can i find it.
Plz help me
//USiT
the dll 's are on the installation cd ...
cinemaster (not the new one)
just extract the dll's from the installation setup (which is for nt4) and put in your system32 folder ..
or install cinemaster 2000"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
//USiT
Syncing manually.......
By GwnLee in forum SubtitleReplies: 3Last Post: 14th Sep 2011, 09:46 -
Syncing 3 Files at once
By Shaunk in forum Newbie / General discussionsReplies: 0Last Post: 16th Jan 2011, 06:59 -
Syncing two videos
By vetteboy76 in forum EditingReplies: 2Last Post: 12th Jun 2010, 19:22 -
Syncing Trouble
By outshimed in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2009, 18:15 -
audio syncing
By projecttemp in forum AudioReplies: 3Last Post: 9th Apr 2008, 21:11
