Hi! I am a newbie at DVD Ripping, and so i would like to
know what are the best tools for DVD to SVCD converting.
Your answers would be very appreciated.
Here's the tools I use...
- SmartRipper
- DVD2AVI
- vob2audo
- Cinema Craft Encoder
- TMPGEnc (with TooLame)
- bbMPEG -
Depends on personal favor.....
Personally I've chosen for;
DVD-Decrypter for ripping (faster then all others)
DVD2AVI (to rip the audio)
AviSynth frameserving TMPGenc (to create the MPG)
TMPGenc Tools (to cut the MPG-file)
VCDImager with Nero (to burn the MPG-file)
The above combination only works for movies without subtitles.
When I wanna include subtitles I've used;
FlasK frameserving TMPGenc (with the frame server plugin)
Another great option is;
FlasK with a CinemaCraft Encoder plugin (for superb SVCD)
For VCD witnh subtitles;
FlasK with the Panasonic plugin (for VCD)
As you see, depends per movie and for me also per mood. I want it be done the fastest and easiest way, so no muxing and remuxing included and no multi-pass for me. Multipass makes the quality some better, but almost near DVD quality (CQ 2100 with CCE) is good enough for me. When I want real (near) DVD quality I simply buy the DVD itself.
But as said; PERSONAL favor. -
my personal fav is :
cladMdec to ripp or smartripper
then use: DVD2AVI to get the files for TMPGenc
then use :TMPGenc with toolame,maenc,sympx or wav2mp to convert to mpeg files and use its tools to cut it
To burn i suggest nero 5.5.4.0 or above to burn vcd or svcd
those are my fav combo
Best tool for HD conversion
By carlmart in forum Video ConversionReplies: 27Last Post: 6th Feb 2011, 11:28 -
Best Conversion Tool?
By cdaz in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 19:06 -
restartable conversion tool
By djelimon in forum Video ConversionReplies: 5Last Post: 30th Dec 2007, 10:44 -
Best DV to DVD conversion tool
By whenloverageswild in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 2nd Nov 2007, 00:50 -
Conversion tool for Real Media files to avi to burn to dvd
By loninappleton in forum Video ConversionReplies: 17Last Post: 29th May 2007, 13:30
