If I finalize a CDRW, does that mean that I can no longer erase or rewrite the disk? I am getting very confused between people who say that a CDRW allows you to rewrite a disk as many times as you like, and others who say that any disk needs to be finalized and you can no longer write on a disk once it is finalized.
Many thanks for your help,
Matthew
you can erase it still.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
some dvd player require that a disk be finalized before they will play any video assets on it. cdrw in theory can be erased thousands of times, but mfr are a little coy about how long you should expect them to laST.
The electronic components of the power part adopted a lot of Rubycons.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
A "why did they do that?" and question about "retro-editing" (if you will)
By takearushfan in forum EditingReplies: 10Last Post: 31st Jan 2010, 22:02 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 14:46 -
silly question about "The QUeen"
By steamedPS in forum DVD RippingReplies: 2Last Post: 10th May 2007, 01:51
