  1. Hi, ok, got a capture card that works like a dream, no converting needed, straight to MPEG, but when it comes to burning VCDs I have a problem! Anyone recommend any decent free or shareware burning software? NERO doesn`t recognise my burner ( SAMSUNG IDE CDRW ), VCDEASY says I need ASPI drivers, and it doesn`t recognise my burner, etc etc. My burner works fine with Data and audio, but having probs burning VCDs!
    I don`t want to spend a fortune on software for burning to find out I have the same problem, so any recommendations?
    System:
    Windows 98SE
    800ghz Celeron Processor
    IDE Hard Drive
    64mb Radeon VIVO card
    Any help appreciated!
    PL
  2. 8) get the aspi drivers (look! ) and use vcdeasy. best prog for newbies.
    The electronic components of the power part adopted a lot of Rubycons.
  3. Member cplevel42's Avatar
    Feb 2003
    Yep, what rabiddog said. 8)
  4. Member Devanshu's Avatar
    May 2003
    If I'm not mistaken, doesnt nero have its own set of aspi drivers? Anyway...check under the tools section of this guide to find some good ones.
