HI everyone,
I'm using WINDVR Plus to capture using an adaptec PCI avc-2410. When i go to option to try to change the encoding format, it just says "MPEG" and is grayed out so i can't access the list to change the encoding format. Why is it grayed out? Thanks!
Becuase this is a Hardware Base MPEG Encoder which dose everthing in REALtime so you can't change the encoding format to anything eles other then MPEG.
Change video to another format?
By Venessa@123 in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2011, 03:10 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 20:01 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 10:42 -
Can I Change Format???
By jmarkt in forum Authoring (DVD)Replies: 2Last Post: 30th Jul 2007, 16:48
