i got nec 1300a with latest firmware and am having probs finding a cheap disc that it will write to at 4 speed i recently had some purple top ritek brand ritek dye discs at a pound each which were excellent and wrote at 4 speed but i hear they have been disscontinued i tryed loads of other ritek dye discs but altho they say they are writing at 4 speed they take half an hour so are writing at 2 speed
obviosly i could buy the tdk or verbatim discs but they just to dear any help would be appreciated
I use Arita DVD+R x4 which are a ritek purple dye.
These work brilliant on my ND-1100A at 4X so I guess that they will work on the 1300 too (since they are +R not -R)
I got them for about £23.50 + delivery for 25 pk from a UK website (http://www.blankdiscshop.co.uk/acatalog/SVP_Communications_Special_Offers_15.html) -
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
I use Traxdata dvd-r x4 in my 1300 with no problems. (Traxdata apparently is owned by Ritek, recommended by NEC for the 1300) £9.99 for 10 at www.blankdiscshop.co.uk
[I use Traxdata dvd-r x4 in my 1300 with no problems. (Traxdata apparently is owned by Ritek, recommended by NEC for the 1300) £9.99 for 10 at www.blankdiscshop.co.uk]
Yeah, I used this media as well and works fine, on their website(blankdicsshop.co.uk) they have DVD media recommendations for the burner.[/quote] -
Hi
I use bulkpaq. They are orange labelled 4x dvd-r CHEAP disks and I get 'em from www.dabs.com They only cost approx £22 (including postage and VAT) for 25 disks. They dont come with boxes or anything they are just on a cylinder.
If you want to look at em go to the website and in the quicklinx box type "2HB3".
They work fine on my NEC 1300A( which i've updated to herries firmware 1.05) using CloneDVD and AnyDVD.
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 14:24 -
Can you burn at higher than the media advertised speed?
By tamgelikah in forum MediaReplies: 13Last Post: 19th Sep 2008, 05:57 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 03:41 -
Speed Versus Recording Quality on Verbatim DL Media
By SCDVD in forum MediaReplies: 5Last Post: 26th May 2007, 00:27
