I have recently had to re-format my Hard Drive, and I have re-installed TMPGEnc 2.521.58.169 (the most up-to-date version), and when I load the WMV file into the appropriate areas as I had done numerous times before the re-format, and changed the settings for highest quality etc and click start, it gets to the 5 second part of the file and then freezes. I then click stop, and then the program will not let the button click as the program is not responding. It does it at the same spot of the file every time. I tried installing an older version of the program, and that didn't work either. I moved the Direct Show file that is in the Environmental Settings to Priority of 4 as I think that is what it used to be when it was working.
Any suggestions as to what the problem may be? Thanks for any help in advance.
perhaps that particular file you are trying to convert is corrupted? I would have said use asftools to try and repair the file, but since it is wmv file.. Hmm try this rename the extension to an asf, use asftools and see it it loads it in, if so, use it's repair function and see if that helps.
i have no idea if an actual wmv file repair program exist, or if it is just easier-- try to download that file again -
Thanks for that suggestion, I'll give that a try. The file does play on the computer, but at the very start, it does appear to have like one or two bad frames where it goes a bit blank, but the rest seems to be fine. I probably will just have to download it again if this doesn't work.
Convert mpeg-2 to wmv
By king71 in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 04:26 -
WMV won't save my file
By davido53 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Nov 2009, 13:19 -
WMV file has 'extra text' at end of it & PS3 won't play...
By fatguy in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2008, 12:40 -
How can I convert WMV to AVI or MPEG?
By betlysmith in forum Video ConversionReplies: 6Last Post: 25th Nov 2007, 02:02 -
Convert mpeg-4 to wmv with super
By Kalash109 in forum DVD RippingReplies: 2Last Post: 17th Nov 2007, 07:14
