i'm looking to get a new hard drive, primarily for video capturing, with the intention of fitting it into one of those firewire drive cases.
anybody got any links to decent drives? preferably as fast as possible as they'll be for capturing...
thanks!
-Mark
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Can't recommend a particular drive, but I've had good experiences with www.dabs.com
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I'd take a peek at the Maxtor personally, it's the one I'd always pick up from now on.Originally Posted by geek rock
I have a couple of D740X 80gb's which have been wonderful but remember the key factor with a drive set up just for capture; don't use it for anything else, no storage, nothing, and format it after each capture, a low-level format will be fine
Personally I use ebuyer in Sheffield, they're great and are no hassle with returns.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
firewire drive normally very expensive
A place that i use is www.ebuyer.com make sure you know what you want as the after sales service is abysmal, but the prices are good. They are also selling an ide to usb2 converter so you can take a normal internal drive and connect it with this plug to an usb port. Only £20 ish.
I fancy making my own little wooden "coffin" for a hard drive!Corned beef is now made to a higher standard than at any time in history.
I would recommend you visit a local computer fair, especially as there is no vat on the price. So you can get a hard drive dirt cheap.
Paul -
Think he might have got it sorted by now Paul. It was 7 years ago!
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Buying online, Aussie members look at this.
By blinky88 in forum ComputerReplies: 1Last Post: 30th Jul 2009, 14:04 -
Advice needed for buying new hard drive.
By dafoe in forum ComputerReplies: 4Last Post: 6th Feb 2009, 17:54
