Thinking about buying a Canopus ADVC-100 and was wondering what is a good capture software to use?
Results 1 to 9 of 9
I'm about to buy one too and intend to use Pinnacle Studio 8.Originally Posted by Blkout
A lot of people complain about it but for me it's been flawless.
I did some seraching of the forum and found quite a few people use it (although I wouldn't recommend it for anologue capture).
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
DVIO is what I use to "capture" DV-avi from my digital camcorder. I believe the Canopus does the same analog-digital conversion as some camcorders.
DVIO is very small, it lets you select if you save as type 1 or type 2 dv-avi. It's just "capture" (actually file-transfer), and nothing else.Just because you aren't paranoid, doesn't mean they aren't out to get you! -
Oh yea, I don't know if this matters or not, but I plan to use the ADVC-100 just for converting VHS to DVD.
In that case, if you're on a budget, consider the ADVC-50.Originally Posted by Blkout
It is exactly the same as the 100 but lacks:
1) the ability to output back to tape (but you don't need that)
2) it doesn't disable macrovision (but I have a cheap scart thingy which does this for me at source).
By the way, what do I need to do to PLAY an AVI file "back through" the ADVC-100 to tape?
ScenalyzerLIVE is popular amongst us Canopus users, although I'm using Vegas 4.0 to capture the DV files "exported" from canopus .
Your original source doesn't matter, everything ends up in the DV format.
I'm going to try the DVIO program also, since its small
32kb!
Question, do these programs differ in quality?
After a week of using this card, I've tried multiple programs and ScLive seems to be the best overall. DVIO is a small program but you don't have a window to view what you're recording and there aren't any other options, just record only. ScLive is the most flexible program I've used so far for this card.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 13:21 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 08:39 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
