IE6, I have found no need to change.
Results 31 to 42 of 42
Avant Browser has the following things going for it.Originally Posted by vitualis
1. Flash Animation Filter
2. Built-in Pop-up killing thingy
3. Multi-Window Browsing and tabbed browsing
4. Real Full Screen Mode just like IE cause its based on it.
5. Built-in Google Search Engine
6. Safe Recovery
7. Skins
Though I hate MS, IE gives me few problems, since avant is based on IE it maintains full compatibility with just about everything out there... including Plugins, ActiveX controls and such. So far the only thing to reject me is Windows Update itself. -
all you need to do is click the DEAVTIVATE CACHE button and it should work like a charm.Originally Posted by flaystus
I'm using WaMCom/Mozilla 1.3.1 on Mac OS 9, which is Mozilla plus a lot of post-release bugfix patches. On the Linux machines I usually use Firebird, sometimes Epiphany or Konquerer. On the Windows PC I use IE, I do so little browsing on that machine that it's not worthwhile to download anything else. I've mostly stopped using Lynx in favor of Links. It's a newer text-only browser that actually has reasonable support for the tables and frames that are (ab)used so much these days.
I think one more thing that Mozilla has over IE is image filtering. Unfortunately it's not as practical as I would like (at least in the earlier releases that had it, I haven't tried the latest), but it's a good start.A man without a woman is like a statue without pigeons. -
IE
There is nothing wrong with IE. MY html codes appears wrong in all other browsers. -
*Shakes his head sadly*Originally Posted by galactica
If only it Did fix it for me, but it doesn't.I still have to force manual refreshes. EVery tip I've found to disable the cache just doesn't work. -
I use Netscape 7.1 for almost everything. The pop-up blocker is fantastic. Cookie management is easy enough, though it is tiresome sometimes to have those "allow cookie" alerts pop up for sites I haven't been to. The email client has a simple look which I like and is pretty customizable.
I use IE for whatever I can't access with Netscape. That usually means sites owned by M$. -
Netscape 7.1 = AOL bastardised Mozilla...
Regards.Michael Tam
w: Morsels of Evidence -
People can call IE crap all they want, but 90% of the world uses it. Me included. I defected to it about a year ago... having used Netscape since it came out.
Issues with my web browser
By alintatoc in forum ComputerReplies: 9Last Post: 23rd Sep 2009, 03:27 -
What web browser do you use, and why?
By louv68 in forum ComputerReplies: 21Last Post: 21st Jul 2008, 21:07 -
Best Web Browser for OS 9.1
By blinky88 in forum MacReplies: 1Last Post: 26th May 2008, 17:11 -
RIP netscape web browser...
By Webster in forum Latest Video NewsReplies: 11Last Post: 30th Dec 2007, 04:00 -
Are you using special toolbars in your web browser?
By yoda313 in forum PollsReplies: 23Last Post: 29th Oct 2007, 16:46
