hi
ive edited a mpeg file in virtual dub mod but when i save it and it's converting the new one ive edited it use's all my disc space?
it got halfway through and used 19GB!
what am i doing wrong?
THANK'S![]()
In short:
You have to choose a compression. It should have warned you with a popup. Uncompressed video is big.
More detail:
When you open the mpeg, VDubMod decodes/uncompresses it for display. VDubMod can not compress back to mpeg so you have to save your changes to an avi file and then recompress/encode that to mpeg. You could also frameserve to an mpeg encoder. This skips the avi encode but not the mpeg re-encode.
Generally, re-encoding mpeg is not considered a good thing. However, depending on the source, it may be fine for you. After all, DVD to DVDr, SVCD, VCD, etc is all about re-encoding mpeg.I mean it in the nicest way.
Simple guide for Virtual Dub Mod 1.5.10.3
By s_joy09 in forum Newbie / General discussionsReplies: 35Last Post: 31st Jul 2010, 16:33 -
Virtual Dub Mod video combining?
By wcdeich4 in forum EditingReplies: 1Last Post: 18th Dec 2009, 08:18 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Queue files in Virtual Dub Mod?
By leogeo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 03:13 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
