Title says it all. How can I shut down a computer with a scheduled task, even if there is still an application running. I didn't see anything in the windows help menus to shut it down. But it will tell me how to wake it up.Running win2000pro.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Try a GOOGLE Search of
schedule windows 2000 shutdown
and you will get many hits for programs, scripts, hints and links to articles on how to do this. -
SHUTDOWN.exe (Win2k Resource Kit now a standard command in XP)
Shutdown the computer
Syntax for NT/2K (see below for XP)
SHUTDOWN [\\Computer] [/L] [/A] [/R] [/T:xx] ["Msg"] [/Y] [/C]
key
\\Computer : A remote computer to shutdown.
/L : A local shutdown.(under XP this is a logoff only)
"Msg" : An optional shutdown message
/R : Shutdown and reboot
/T:xx : Set the timer for system shutdown in seconds.[20 sec. default]
/A : Abort a system shutdown during the timeout period.
/Y : Answer all following questions with yes
/C : Force running applications to close.
ATTENTION: If you use the /C parameter shutdown will not
prompt for File-Save in any open applications.
This will result in a loss of all unsaved data!!! -
Thanks, wish I had the resource kit now
That's still an optional, pay for it component right? Maybe I'll have to down grade to XP. Wonder if the Pinnacle Bungee will run under XP? Guess I might find out.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Found a bunch of freeware stuff here:
http://www.webattack.com/Freeware/system/fwshutdown.shtml
Still surprised that 2K doesn't offer something as part of the scheduled tasks.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
8) I use a nice little proggy called timed shutdown. It allow four different triggers to cause shutdown
timed
disk activity
cpu activity
network activity
Works very well and I have nver had any problems with it.
Timed shutdown by tinnes freeware, which is nice. :PCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Computer Won't Shut Down
By DarrellS in forum ComputerReplies: 5Last Post: 23rd Jun 2010, 01:51 -
Computer shut down initiated (Log)....... (ConvertXtoDVD4)
By hanse in forum Newbie / General discussionsReplies: 0Last Post: 25th Mar 2010, 16:30 -
Computer shut ByItself, Surge Protector Beeping
By kerrex_2006 in forum ComputerReplies: 3Last Post: 8th Apr 2009, 03:23 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 13:34 -
AVI2DVD causing computer to shut down
By Lynxer in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 10:42
Running win2000pro.
