I know I'll take alot of razzing for this.![]()
How do I disable autorun for the DVD drives in Windows Me??
Results 1 to 12 of 12
You create your own reality. Interested in media servers and HTPC? Can we talk?
I tried my computer, control panel, system, devices. There is no check box or anything I can find. I know it can be done. Please help?
You create your own reality. Interested in media servers and HTPC? Can we talk? -
Couldn't remember since I changed to XP, but here goes.
Control Panel -> System -> Device Manager -> locate drive
right click - select Properties - It's called "Auto Insert Notification"
remove the tick :c)
resisted razzing :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Thanks, Gees.
I'll try that when I get home. I think I remeber seeing that option, but thought it was not the right one.
Yeah, well they tried to trick you by calling it something you might not expect. :c)
You're welcome. :c)There's no place like 127.0.0.1
Hey Gees
How do you disable it on XP (besides holding the Shift key). Anything in Control panel ?? -
No. :c( It's not so easy in XP. I think it requires a registry entry change, which is always tricky. I've never found all the necessary info anywhere.
What I'd TRY - is keep putting different discs in and hope one triggers that box that pops up and - if lucky - click the "Do Not Do Anything (I want to handle it all on my own, thank you very much!) option. :cD
I set mine from the start to do that, so I have no auto-run probs. But every so often a disc will trigger that box and I always choose the (edited) option above.
Good luck. :c)
- typosThere's no place like 127.0.0.1
I am on Win2K and I can't disable the Autorun on the DVD-ROM and the Burner Drive.
There is nothing there available to make it permanently disabled and not like a Win98 computer can which is always off.
I have to push the shift key while inserting a disk such as a music CD for Mp3 conversion in the Hard drive.
Anyway, I don't use the disk drives very much as everything is in the hard drive or from a server in the network. -
If you use the windows support center, which is on every version of windows under that start menu then H, it has answers to do anything you want, including this one
Didn't help me for win2000.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
If you have one of those tweak-xp programs you can disable it from there too.
Connecting the DDR and CD-Rom drives
By hellfire45 in forum ComputerReplies: 17Last Post: 4th Oct 2010, 01:57 -
Help with cycling through/disabling soft subs from mkv->DVD conversion
By herbster in forum SubtitleReplies: 1Last Post: 24th Nov 2009, 01:44 -
Find Firmware for CD/DVD Rom drives?
By Ghtpua in forum ComputerReplies: 8Last Post: 26th Aug 2007, 14:27 -
Autorun Precedence - DVD & Autorun on the same disc
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 20:26 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 11:37
