I'm at step 4 on Galactica's guide and using Toast Titanium 6.0.1 that I just downloaded from roxio.com
I have backed up and then compressed the dvd using dvd2oneX. In Toast I dont have an OTHER tab instead I have a VIDEO tab with DVD option so I select it but it won't accept the folder labeled the movie (ex PHANTOM_MENACE) witht the AUDIO_TS and VIDEO_TS files. It will not allow me to drag it, it only accepts the vob file. Please Help...
BTW the DATA tab on Toast accepts the whole folder if that helps.
There is no 'other' tab in Toast 6. What you need to do is select the 'data' tab, then below and to the left is a circle icon (opposite the help (?) icon), click it and a drawer will open from the left of the main window. It's the 'show/hide disc options' drawer, in there, select 'DVD-ROM (UDF)' and then drag the folder containing your AUDIO_TS & VIDEO_TS folder to the main window, then burn.
Right, i have only updated the tutorial on this site, the stickey at the top, but not my webpage yet.
so just do as said and you will be fine. -
not sure how this message from me got here, so anyway 8)
woooohoooooooooooo that worked and i have my 1st dvdr after only 2 coaster
thanks timtmgd and galactica
Important question about burning with Toast
By mac&me in forum MacReplies: 1Last Post: 24th Nov 2010, 18:47 -
Burning AVI Files in Toast 7
By Luckyword in forum MacReplies: 9Last Post: 16th Jul 2010, 12:05 -
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 22:11 -
burning clips with toast
By 3mselect in forum MacReplies: 6Last Post: 29th Oct 2008, 12:54 -
After burning in Toast: subs: no and yes.
By Levina in forum MacReplies: 7Last Post: 13th Apr 2008, 16:50
