i just got a new 50 inch big screen high definition TV. I need your advice to get a DVD player and get the best picture posible with my new TV. which one have the best resolution out there? thanks for looking
I also have an HDTV TV and i like to match brands I have a panasonic tv and I just purchased a s35 dvd player and I also have a DENON 1805 5 dvd changer because it has the farouda chip for progressive scan which can give stunning results also remember to use the component video cables where you can enjoy progressive scan just my 2 cents
:P
Well if you're screen has DVI input (which it should) then I'd go with the Bravo D1. The D1 has a DVI output and also has the ability to upscale DVDs to 780p or 1080i. Current initial responses on the avsforum.com has it as edging out the Lite-on 2001 when using the DVI outputs compared to the Lite-on analogue component output, although the Lite-ons is very good also. They both use the same chipset. When you use DVI outputs you're keeping it in the digital domain.
http://www.vinc.us/level2.asp?id=31&PID=21
Buying a new BD/DVD player - What should I buy?
By BobLoblaw in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2011, 21:10 -
advice to buy for dvd player
By rcrally in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2009, 15:24 -
Best Buy dvd player
By golfer in forum DVD & Blu-ray PlayersReplies: 7Last Post: 21st Feb 2009, 13:59 -
Seeking advice to buy better DVD Player...
By SimpleSymon in forum DVD & Blu-ray PlayersReplies: 13Last Post: 28th Oct 2008, 21:10 -
Buying a Divx DVD player.....Which one to buy.
By Hank Kinsley in forum DVD & Blu-ray PlayersReplies: 9Last Post: 15th Jun 2007, 09:53
