Results 1 to 9 of 9
    Mar 2002
    East Tennessee, USA
    Subject's self-explanatory ... VOBsplitter is useless to me, because I need to actually SEE what I'm splitting ... how the hell is anyone supposed to cut out part of a VOB file based on bytes anyway??
    BTW, I don't want to have to re-encode anything; I just want to say "Start at THIS frame and stop at THIS frame," go take a leak then have a new VOB file .... can't be THAT complicated, can it?
    Mar 2003
    Uranus
    It's far more complicated than you will ever probably know.
    If you really have to do that , You need to convert to AVI and re-encode
    afterward.
    Ulead editors can do it , or you can use Vdub.
    Sep 2001
    Try MPEG2VCR. It has a 30 day free trial.
    Tearren
  4. Try Chopper Xp In tools section that will work for you
    Mar 2003
    Uranus
    Chopper XP only claims to be able to get within 1 second.
    DVDShrink will do it but won't get within a frame either.
    I have had problems with MPEG2VCR (and everything else almost)
    when the video is NTSC Film. with A/V sync .
  6. Originally Posted by Tearren
    Tearren
    Where do you get the free trial of MPEG2VCR from? I have only ever seen Womble offer a free trail of the MPEG1 version, which is bugger all use if you want to test it on MPEG2 files!!
    Mar 2003
    Uranus
    I think you send them an email or something.
    Sep 2001
    http://204.2.106.205/tle-request.htm
    Fill out the above form. They will send you an email with a download site.
    Tearren
  9. Thanks.
